I own a 1999 Toyota Camry LE with the 2.2-4cyl. I've owned the car since new and was accustomed to receiving outstanding fuel economy until the last year or two. The car currently has 85,000 miles and is well maintained with an oil change every 3,000 miles.
I am currently experiencing numerous problems with the vehicle. Currently it consumes about one quart of oil every 1,000-1,500 miles and returns fuel mileage of around 22 mpg. When the car was newer I was not as accustomed to checking the oil regularly. About four years ago I happened to check one day I took the car in for an oil change and they found the vehicle at least 2 to 3 quarts short of oil. Since that point I have always been dilligent to check at every fillup and add as necessary. Around the same time my timing belt failed at around 57,000 miles and was replaced along with the water pump.
I am baffled as to the loss of oil. The engine doesn't smoke and the plugs always seem clean when I check them. I've replaced the plugs, wires, air filter, and PCV valve regularly and yet my mileage has continued to worsen. It is not delivering any CEL's
About 3 years ago I took the car to the Toyota dealership to see if I had a sludging problem and was turned away saying that they could find no evidence under the valve cover.
Can anyone offer suggestions. This mileage is awful. What would you recommend?
