Okay so I have a 99 corolla of course automatic (only 140k miles) and everytime I shift into reverse or into 2nd, the whole engine jolts. And specifically going from 1st into 2nd theres a noticeable delay followed by a strong jolt, and it has nothing to do with temperature. Im not sure if its the engie or transmission specifically, but its the whole assembly. Ive alreadt replaced all engine mounts though and the transmission mount, because Ive read thats a likely problem. Right now Im replacing the timing and pistons. The pistons are for another issue, but I read somewhere that if your car is having shifting issues then its good to look at the timing. The engine burns oil like hell and thats why Im replacing the pistons, Ive read that my generation has terrible pistons.
I dont know if the pistons issue somehow links to the rough shifting but Im out of ideas at this point. Ive read it could be any issue from the O2 sensors going bad, to the damn torque converter being ruined. Theres just so many things it could be. I was hoping maybe someone could help pinpoint the issue. Im pretty sure the ATF is correct, everytime I check it its a a little below whats considered too much on the dipstick.
Some people seem to think the MAF could be causing the issue, or even a vapor solenoid, or even a shift solenoid in the tranny. Im in the middle of the job I mentioned above, so Im not sure if the problem will persist after reassembly. But if it does I was hoping to get some feedback in case it does. Does anyone know what the hell could be causing this? Any and all help is appreciated.
- Some dude whos trying to learn about cars
