On the topic of that DIY kit, I've seen those things before. And they sell that to anyone there? For any work that involves refrigerants over here, you can only have it done by someone that is licensed. None of this DIY stuff.
No leakage is acceptable. A typical automotive system will last well past 6 years before a leak appears. I'm not fond of the state government regulating who can service an air conditioner, but R12 was quite nasty to the environment, and reports are that R134a is nearly as bad. Nobody should be venting these gases to the atmosphere, and nobody should be playing with these materials if they haven't had some training. When someone asks where the valve is to add refrigerant, I worry that perhaps he hasn't received his certificate yet.
I've always wondered about those 'recharge kits' - the gen 3.5's AC takes a bit longer to get cold in the past year. However - everything is original and after the air gets cold, it stays cold. Is it wise to perhaps get the rubber hoses replaced (after all, it's been 14 years) and get the system evacuated and recharged? I'm not sure how you maintain an air conditioning system so pardon the n00b questions.
Alrighty.. How good are the gauges on those DIY cans? I'll ask my cousin if he has the tools available or knows who does. I have to borrow his OBD-II scanner too.A good a/c guy can pop the gauges on and know in a couple minutes if the pressures are in the ballpark. If it is just a tad low and you haven't added refrigerant in eons, then adding a few ounces will probably do the job and spending $80 is overkill. If it is way low, then yes, check for leaks.
I would not replace the hoses on a 14 year old system unless you have to. It's just too expensive. You need to replace the hoses, the drier, and then evacuate to a couple atmospheres for an hour or longer before recharging. Time and money. Check the price of the drier and then rethink this.
Thanks for the information. A local tire/brakes/AC place charges $79.95 for an AC leak test and it includes up to 16oz of R134a. Maybe I'll take it down.
I am still very impressed with the durability of Toyota's AC system. My aunt has a '94 Accord and she is getting ready to repair her AC for the third time. The first two times it was major parts like the compressor/condensor/evaporator but this time I think it's just leaky hoses.
Here's a test question for only the guys who think the kit is a great deal: A car's air conditioner is operating. The compressor is engaged. The high pressure measures 235 psi and the low pressure side is measuring -3 psi. What is wrong with the system and how do you fix it?
