1 - 5 of 5 Posts
日産自動車パ&#
2004 Nissan Maxima
My Camry is just having one problem after the next...
This time its the A/C Generator. The Pulley attatched to the belt that goes to the alternator and the engine is wobbling, and making a loud grinding noise. We pulled the belt off completely and theres no noise, so it is definitley an issue with the A/C Generator.
My question is, since the A/C doesnt work anyway (it goes on but no cold air), what is my best option?
Is it possible to swap in a belt from a Camry w/o the A/C system and just pull the A/C generator out
Or should I just replace the Generator from a junkyard and leave it at that.
Heres a video of the sound: (sounds like a wine)
http://www.youtube.com/watch?v=xADlLeZng5k
3s-gte in a Camry?!?
'89 Camry Alltrac
Go to the auto parts store and get the belt for a Camry without A/C. Put it on, bypassing the A/C compressor and that should solve your problem.
You may need to remove the compressor to get the belt to fit, but probably not.
-Charlie
日産自動車パ&#
2004 Nissan Maxima
Discussion Starter · #3 ·
-Charlie
Good thing they made the car without A/C. Idk why but for some reason i didnt think they did.
And yea theres just enough room there when the belt is fully tightened that the belt wont hit the A/C pully.
If i disconnect the Generator, do i need to cap off the lines? I see that the generator is just 4 bolts, anything else i should know?
セクシーの定&#
Camry Touring
+1 on the bypass with a new (shorter) serpentine .
I'd say you'd probably need a re-gas to get cold air again, if you want it.
Couldn't over-tightening the serpentine (and having it like that for some time) cause the A/C to make that high pitch whirring noise at the compressor?
日産自動車パ&#
2004 Nissan Maxima
Discussion Starter · #5 ·
The compressor itself is vibrating, and the pulley sometimes shakes.
I didnt really need the A/C considering it didnt work before. If i really wanted to i would just throw another generator in there if it starts getting hot.
1 - 5 of 5 Posts
