Hi guys!
I have a 1993 Camry LE 2.2L
Today my middle A/C vents blow barely to no air when the setting is on face mode. All other modes work except the face one. The driver and passenger vents work but blows weak.
What I noticed is that most of the air comes out from the defroster vents and some on the vents on the outside of the car by the windshield on all modes.
I tried checking continuity with the switch all of them seems to check out. I also tried checking the ASV near the throttle body. There is continuity between the two points and the resistance at 68 degrees F is 7.83 ohms. Some guys said that the issue could be the vacuum from the ASV but I checked the hoses and there were no cracks or holes. I looked at the servo motor and it seems fine, I think. There arms were moving and all of them slide without any resistance. I couldnt find a blown up picture of the servo motor so im just assuming that the motor is fine.
On the video below, I showed that I changed the modes. When I switched it to the face mode, there is a delayed "thump" which I have no clue where its coming from.
Please help. Thanks!
