1 - 5 of 5 Posts
All,
thanks in advance for the help.
I have an 03 Camry 4cyl. The A/C Light just started flashing and the clutch never engages. I have checked the fuses and relays in the Dash Fuse box and the Under hood Fuse box. All seem to be good and working.
I have found this TSB EL011-05..... Don’t know what is is for sure, but t may help. Can anyone run an alldata or tell me what it is.
Thanks
Matt
If you are low on freon your A/C/ clutch won't engage because of the low pressure switch. You should be able to check this by jumpering the switch. However you may have a leak that needs to be fixed by a GOOD a/c shop!
Gary
Banned
Camry / 2WD Pickup
Sorry, but the only experience I have w/ this type of problem was w/ my Gen 1 Camry.
The A/C light was blinking when I tried to run the A/C. I had to install a new RPM sensor into the compressor. It was a PIA, since the system needed to be opened.
keltymd said:
There is not a leak in the A/C system. the clutch would engage for a second if there was, unless it was completly empty.
Exactly! Have you checked your pressures? High side and low side? Until you do you may not know if you have a leak!
Gary
1 - 5 of 5 Posts
