1 - 20 of 42 Posts
Trailer Trash Engineer
^that there is the chemical ideal stochiometric(sp?).
Best power at wot will be richer, as in lower number like around 12 or 13:1 and best cruise will be a bit leaner, generally around 15.5:1 or 16:1 I think.
For some reason Mazdas, at least the Protege, and its successor the Mazda3, run rich. I drive a Mazda Protege and it's widely known the system runs pretty rich from the factory. It's gotta be some Mazda way of thinking, perhaps too rich is safer than too lean? I dunno...
camrys blow off too!
06 subaru wrx wagon
too rich is just as bad as too lean. ive seen many a car have gas washed cyls. perfect way to ruin a block
Too lean may result in hot spots, detonation, etc., or even melting, right? What does too rich lead to? I have not heard of gas washed cylinder walls before.
Grenaded piston
Yup.
Fouled plugs, bad fuel economy, etc..
The cylinder walls get lubricated by oil. If theres to much fuel in the cylinder, the fuel washes away the oil.
fuel washed cylinder walls are real, more ring bore and skirt wear, bad thing, also rich mixture causes cat con to run very hot and may melt internals blocking exhaust. O2 sensor should keep mixture around 14.5:1 (+/- 0.5:1)
running rich will actually cool the engine better; which is why you go richer if you are detonating.
marvelicious, i disagree that optimum power is rich, unless its a turbo engine. if you look at some dyno charts(ones that show a/f at the bottom) for all-motor engines, youll notice they make the a/f leaner to increase power. stoichiometric is not a compromise for power and fuel efficiency, but rather for the gasses coming out of the tail pipe.
Discussion Starter · #18 ·
A leaner engine will run hotter because when ever you ignite something with more oxygen it will burn more completely, the outcome is a hotter combustion.
Where as a richer engine will not burn all the fuel completely.
A leaner engine isn't necessarily more power, it depends on the engine, that is why people dyno tune. To get the A/F right to obtain max power etc...
1 - 20 of 42 Posts
