I just started noticing that some transmission fluid was leaking on to the ground when I park it in the garage? The leak is not that bad. I couldn't find where the leak is coming from? I just change my transmission fluid today and it still leaks a little. Check the filler plug and the drain to make sure they were both tight nothing. But when I check the engine bay and I found small splashes of trans fuild all over? Please help! Where could the leak be around the engine bay? What does that mean? Car runs like brand new but LEAKS..?
05
05
