1 - 7 of 7 Posts
I've been dealing with this intermittent problem for a while now with my 95 Pickup 4X4 22RE.
The truck has three "modes" it runs in.
Mode 1 - Runs perfect. No issues. Good power, starting etc.
Mode 2 - Check engine light comes on. Power cut significantly. Still runs and drives, albeit poorly.
Mode 3 - Engine stalls. Check engine light on. Will not start...unless I crank the heck out of it and floor the gas pedal, then it slowly sputters to life
When these different modes occur - I notice mode 2 and 3 happening more after the truck has sat for a while. They seem to go away after driving for some time, like an hour or so. But during that hour, there could be any combination of mode 1-3 for any amount of time.
It can go from not starting at all, to running perfectly. For example, one time it stalled completely. I called a tow and had it taken to my indy shop. After a while I get a call to say that the truck is running perfectly, they could find nothing wrong. This is before I discovered that flooring it when starting could usually nurse it back to life. So it can go from not starting at all, to an hour later, starting and running perfectly.
Things that don't seem to correlate:
  • Engine RPM. Can happen at any RPM
  • Road speed. Can happen at any road speed
  • Throttle position. Can happen from full throttle to idle and anywhere in between
  • Engine load. Happens under any engine load.
Things that do seem to correlate (MAYBE, I'm not totally convinced of the correlation)
  • Seems to happen after truck has been sitting for a period of time. The longer, the worse it is
  • Seems to go away after the car has been driven for some time. Like today, after a lot of issues and multiple stalls, it went away. I was running a lot of errands all day.
Code I captured one time when I caught the engine light on long enough for me to test:
Code 25 - Air–Fuel Ratio Lean Malfunction
Note that it has been a while, and I'm going by memory. I thought when I looked it up way back then, the descriptor said 'intermittent lean condition', but when looking at the manual now, I see that code 25 says the above. I may have remembered something wrong but I'm pretty sure I remember 25 as the correct code.
So, what component can intermittently malfunction, then go back to normal? Sometimes causing a lack of power, or a total stall. Sometimes preventing from starting unless I floor the pedal and crank a lot. Other times, the truck runs flawlessly, all within the same drive. It can rapidly shift between the three modes at any time and any amount of times, but eventually if I have a long enough driving session, the issues go away...usually...I think.
When it completely stalls (and before I figured out how to start it with pedal floored) I would seem to detect the smell of gas while endlessly cranking. Same for right after I would nurse a start out of it with the pedal floored.
The truck always starts fine on the first start of the day.
I looked at my records because I thought I had replaced the O2 sensor, but I don't see anywhere that I did so. In 2011 (and not that many miles ago) I removed and sent the injectors out for rebuilding.
One with the farce
I’ve had very similar symptoms in the past, with the culprit being the O2 sensor.
Discussion Starter · #3 ·
Interesting.
It took writing this post to realize that I'm pretty sure I've never addressed the O2 sensor. Kinda surprised. According to the error code description, and your experience, sounds like a good place to start.
Have you ever cleaned your Throttle Body? Scotty Kilmer has a decent YouTube on DIY'ing it. Even if it doesn't fix your situation, it won't hurt anything.
Discussion Starter · #5 ·
Yeah, that's what the mechanic tried after not finding anything wrong. Didn't help.
Big difference in price between local stores and rock auto. Think I will mail order it and wait. Gonna order both of them and go with Denso. I like OEM, especially with that era of Toyota. Everything was overengineered.
Discussion Starter · #6 ·
Do these look like the right parts for my 95 4WD DLX 22RE, US made w/CA emissions?
DENSO 2344052 {Click Info Button for Alternate/OEM Part Numbers} Info
FitsUpstream; RWD; w/ California Emissions
orUpstream; 4WD
and
DENSO 2344154 {Click Info Button for Alternate/OEM Part Numbers} Info
FitsDownstream; RWD; w/ California Emissions
orDownstream; 4WD; w/ California Emissions; USA Built
orDownstream; 4WD; For vehicle built in Japan; Calif.
I always buy OEM Toyota (Toyota, Denso, AISIN) when available. I've come to believe that half of failed repairs are due to crummy Chinesium aftermarket, non-OEM parts.
1 - 7 of 7 Posts
