You can swap in a 5spd.
I think that tranny holds about 4.2 Qts total, but to just drain and refill takes 2.6 Qts.
It sounds to me like the (C1) forward clutch pack is not getting sufficient pressure. The piston for that might have a damaged seal.
Did you get into the valve body also?
