they do, just not for the 265/75-16's. the 265/70-17's on my truck are c-rated (which are essentially the same dimensions). to the OP, i lost about 1.5 mpg with the bfg's, thats with them on the stock sport rim. no change with my new procomps. out of curiosity, why'd you rule out the revo's?yes like eyedoc said. Its beacuse they are heavier too. I wish they made the BFG at ko's in a C rated tire.
Upload your photo's to Photobucket.com and click the direct link tab, then comeback to TN click on the little photo icon above the text box, paste the addy and Bam, theres your pic.If anyone could tell me how to post pics I would post some. Can't find anywhere on here on how to post any. Sorry new member here.
to the OP, i lost about 1.5 mpg with the bfg's, quote]
:disappoin I was hoping not to lose that much in the mpg:ugh3:
what to do, what 2 do![]()
Check out Firestone Destination All Terrains. My cousin just put them on his 2001 Tundra and he loves them. He originally had Revo's (the previous owner put them on the truck), then went to the BFG AT's, and now has the Firestones.to the OP, i lost about 1.5 mpg with the bfg's, quote]
I am fairly certain my next tire will be Firestone Destination AT's. I was checking out a Tacoma at the store today that had them, they look like a good tire.
Anybody catch this post? Now I'm wondering if the mileage figures offered took into account the speedo error because of the larger tires.i have a stupid question. did everybody get their speedo and odometer recalibrated for the larger size before calculating mpgs?![]()
My cruising RPMs were higher with the larger tires...not lower. It took more power for the engine to get them moving and keep them moving. Even with "adjusted" MPG factoring for the larger diameter of the tires you will still see a loss of about 1.5-2 MPG.These Tacomas are very torquey engines and they are geared more for towing than for maximum fuel economy - the slight dip in rpm's (with larger diameter tires) on the freeway might translate into slightly better or the same mpg with larger tires, but your city mpg would take a hit.
This does not make much sense unless your clutch is slipping or something.My cruising RPMs were higher with the larger tires...not lower.
