1 - 4 of 4 Posts
My ABS light on my 1995 Camry LE is on. (231,000 miles). The code was 3-1 for the right speed sensor which i went ahead and replaced. The ABS light is still on but now the code is a steady on off pattern which seems to indicate that all the speed sensors are good. But the ABS light is still on. I pulled the ground off the battery for a few minutes and when i reconnected, the light is still on. Any thoughts would be greatly appreciated. Thanks
1999 Solara SLE, V6, 352,000 miles
might look to see how dirty the sensors are. are you certain that removing battery power clears ABS warnings?
Since writing this i did the erase procedure (jumper between Tc and E1 and pumped brake 8 times in 3 seconds), and disconnected the battery. Light is still on. Now im getting right front wheel sensor open code 3-5 instead of 3-1 before I replaced the sensor.
you could try swapping new sensor to that side and see what happens.
1 - 4 of 4 Posts
