1 - 2 of 2 Posts
2002 AWD 5 speed.
Is it possible to retrofit an ABS system into a Rav4 that did not get it installed originally?
I know I would need at least wheel sensors, decel sensor, ABS ECU and control box/solenoids, hubs, etc. What else?
Is this even feasible to do?
Toyota Collector
Not feasible you will need to strip the car to replace the engine room harness and floor harness. You'll need every brake line under the hood, the ABS pump, 2 steering knuckles with sensors and rear hubs with ABS sensors. And probably some stuff I forgot.
1 - 2 of 2 Posts
