So yesterday I'm was leaving for work in the morning, and seeing as how I live in SA. Texas I went to turn on my ac. Well I switched my Gen 3's system over to defrost the front window real quick, and when I switched back to full upper AC vents....the system clicked over, but the middle two vents locked up or something. I have air comming out of the outside vents, but the inside vents do not work? I cycled through the seperate controls, and everything else works, but alas....no matter what the center two vents do not click over. I was hoping to get some advice on this if anyone has had this problem before, before I go out and dismantle the front to find the problem. Any takers?
And on a second note....does anyone have any idea on a difficulty for replacing the Driver side Front CV Joint BOOT? I was replacing my breaks this weekend and I noticed there was tear in the boot which is allowing my grease to be slung out into the wheel well.
