Hi,
I found in the post in 2004 that Punkrocker had the same problem with camry as I have now with mine.
Let me remind you:
94 Camry 2.2ltr 4Cyl Auto with 160k. the problem is when i floored it at about 4000 to 4500 rpm it starts loosing steam and doesnt accelerate. i have to lift off of the gas to let it shift to the next gear then apply gas after it shifts. the car just had the timing belt done."
The problems is mostly between 3 and 4 gear. (automatic trans.) and max. speed
is around 95miles/h. (it is allowed in Europe)
TPS - ok.
Cat - ok.
map sensor - ok.
Unfortunatelly I did not find what was the reason.
If somebody have any suggestions to solve this problem please let me know.
best wishes,
Tomas
Let me remind you:
TPS - ok.
Cat - ok.
map sensor - ok.
best wishes,
Tomas
