Stab the throttle twice.. quickly
down..
then up
then back down.. see what happens then..
down..
then up
So after many years of DBW Toyota still hasn't fixed this problem or the transmissions either? So glad my throttle is connected by a cable.Stomp it to the floor and hold it there.
There's often a 1 second delay after the transmission downshifts before the engine ramps power back up, as if it's waiting for the transmission to be ready. It's very annoying, but it's normal.
Sometimes the transmission will downshift 2 gears, and then finally go down another as you're trying to actually dart out in traffic. Driving in "S" mode if it's a SE/XSE helps speed up the sleepy transmission response a small bit.
Depends on the car I guess. I don't know if it's the 6-speed autos or just the fuel-economy oriented programming. The 6-speed Taco/Camry are very slow to respond to throttle inputs. The 5-speed Highlander V6 will instantly drop gears and MOVE.So after many years of DBW Toyota still hasn't fixed this problem or the transmissions either? So glad my throttle is connected by a cable.
W95c
It's normal. That's how Toyota's drive-by-wire system is. If you want quicker response, put it in "sport" mode by moving the shifter to the left.Hi - did you sort this out?
My 2014 Camry V6 - lots of power in the engine, but same problem.
not a problem it surely fixed issue in my 2014 not sure about 2016 keep us updatedThanks dude!
Ordered the APEXi now - will report on it when I get it.
If you're right, this will be a Toyota-brand-saver.
