acceleration hop
1856 Views 11 Replies 9 Participants Last post by  Mandy3206
When I have to accelerate hard from a stop sign or the like my ass end hops quite aggressively. I hardly ever get a squeal of the tires but a very annoying hop. Any way to combat this?
1 - 12 of 12 Posts
Put it in a lower gear or don't accelerate so hard?
its called wheel hop. knowing what vehicle you have would better help us to understand how to combat the problem.
usually its caused by the weak rear springs the 2005+ trucks have. the rear springs are soft and allow the axle to wrap up and it makes the pinion point upwards and the axle is basically trying to run under the truck and lifting the wheels off the ground.
an add-a-leaf set-up will usually fix it by loadign the springs up and giving them a greater spring rate will not allow the springs to deform like they are under hard acceleration. depending on the truck you have, it may be easier. 2wd or 4wd? reg cab, extended cab, 4 door?
Oh, I get what he is trying to say now. Thought he was talking about how it hesitates to accelerate.
Do you have an automatic transmission?
do you have lift blocks in the rear? or perhaps your shocks worn out?
Search for "Sharing the wealth" thread. Install $20 helper springs backwards.
I can't believe nobody thought about it, besides me. Where are the old-timers?
ditto!
i have lots of pics in there, too
i got the TSB for the rear susp and still have these installed.
"flattens" everything out in acceleration.
I have the access cab 4x4 and I had the rear leaf tsb done already. I'm going to check on that other suggestion right now.
to get a good feel, accelerate and turn the wheel slightly so you can feel the "squish" in the rear susp.
then intsall the helpers (backwards) and do the same test again
No acceleration hop for me...ever. And no TSB since I wasn't aware of it until after I was out of warranty.
Seeing as I have a non-TRD SR5, some said in the other thread that this helped with the sway around corners. I'd prefer to go the AAL/Bilstein 5100 route, but $$$. For $30, I may give these a try. Wasn't interested before, but I think I am now.
1 - 12 of 12 Posts
