the seal they gave me for the front didn't stay adhered to the composite bed material, so i used a piece of trailgate seal which compresses better in that spot. other than that, mine's mostly watertight.
I have the Access LE on my current taco and my had it on my previous taco and both leak in the same spot in the left front of the bed. I am thinking of runing a bead of silicon to try and seal it up.
I have a different cover on my truck but leaks in the same place.I had my daughter close me up inside the bed with a flashlight and her spray water over the truck.The water was coming in under the plastic cap over the fenders.The cover was sealed so I'm not sure how to fix unless I get out the tube of silicone in which I'm not thrilled about.So as it stands I get the little stream of water that comes down the front corners and run to the back to the tail and drains out the back of the bed.
1 - 6 of 6 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
