All
I have a 98' Camry and it has been fantastic till now.
Still engine/transmission is excellent, it is just that the electricals are bugging me every now and then.
About a month ago following things stopped working about (or exactly at) the same time:
1) power mirror adjusting
2) mobile phone charging outlet
3) digital clock
I am not too concerned about the clock, but I need the charging outlet and power mirror adjustment to be working.
My hunch is it is going to be a blown fuse. But to check the fuse I need to access the fuse box behind the dashboard. When I removed the panel which holds the mirror adjustment switch, I could see a bunch of fuses behind. But the only way to access these fuses will be to remove the dashboard. Or is there some other way I can access these fuses?
I have a Chilton's manual but it does not have a fuse diagram. I need to know which fuse is responsible for mirror, charger outlet, etc.
I would appreciate any help on this matter.
Thanks
Mahesh
3) digital clock
Thanks
Mahesh
