1 - 2 of 2 Posts
My solution to installing the accessory belt without help
Removed right tire, plastic shield (I was working in this area anyway)
Pre routed the accessory belt, left it off the water pump pulley.
Put 19 MM socket and breaker bar on the tensioner - 6 point wrenching location just below the thumb in the image showing the belt routing. Put a floor jack arm over the bar, pulled forward as securing it with a tie down strap.
Worked the belt over the water pump.
Released the tensioner.
285086
285088
1 - 2 of 2 Posts
