1 - 11 of 11 Posts
I needed a 12v outlet that was always on and didnt want to do the mod to change the two in dash ones.
I bought a 12v receptacle from a sporting goods store, a marine 12v outlet with a cover. I removed the tray from in front of the shifter to check for clearance before drilling. I placed it on the passanger side, ran a in-line fuse to a constant on at the fuse panel, and found a ground. Both use a female spade to plug to the back of the outlet.
I can now leave my cell phone in the truck overnight to charge while at work.
The job took 1hr tops to do.
05 TRD Sport Tacoma
Nice work...
OFF TOPIC: I hate your goddamn SN...my name is Kai...and your name is Kai i guess...it pisses me off everytime I see you post cause I'm like that's not me...but that's my name...I HATE YOU FOR HAVING THE SAME NAME AS ME!! *hug and kiss*
ON TOPIC:....sorry about that, still a great job on the mod
· Row Dialin'
I like that outlet. I put one inside of my center console and plugged my GPS in there.
I added a rocker switch to turn on the power when I need to charge the GPS. It's got a green LED indicator when it's on.
I really like that outlet though. I may look into swapping mine out for that one. How much was it?
Discussion Starter · #5 ·
I like your idea of the switch.
The outlet was $8.00 w/ tax.
Check on line or at a marine store they have different types of outlets for boats.
KAI38 not PHI KAI
:D
· Row Dialin'
Discussion Starter · #7 ·
I finally got around to getting the rest of the pictures together.
On the passenger side there is a rubber plug pull it out and trim the back side of it off, its a rubber grommet to pass the wire through
remove the glove box and there is a good ground point under the 10mm bolt.
after putting female spades on the hot & ground wires pluging them to the backside of the 12v outlet run the hot wire through the grommet , going from the engine compartment into the cab.
I ran the wire over to my aftermarket fuse block I installed on the driver side.
The whole install may have taken 1hr counting getting tools, wire etc.
Discussion Starter · #10 ·
i like. why didn't you want to mod either of the ones in the console?
This seemed easier & I already use the other two I needed a third outlet.
[quote the red kinda sticks out in the engine bay. wire loom maybe? anyway... nice install :thumbup:[/quote] It does need wire loom I didn't have any small enough or long enough to put it in. It will take 15 mins to correct later this week.
1 - 11 of 11 Posts
