1 - 2 of 2 Posts
Hi,
I would like to add a circuit to my Toyota Corolla 2009 LE to be able to power a GPS tracker and a door lock/unlock system. Both devices use less than 2A when they are in use.
I got those TAP adapter that you install on the fuse box, but I was confused on which circuit I should connect it to. I need an "Always ON" circuit and an "Ignition" Circuit, both will be protected with their own fuse.
Any suggestions?
Thank you.
Finger Technology Material property Electronic device Hand
Water Bottled water Plastic bottle Drinking water Machine
Text Document Paper Font
Line Text Technology Cable Font
2009 Toyota Corolla S
I added an always on circuit today! I don't have a moon roof, but my fuse box has a 20 amp fuse in it's slot (#8 SUNROOF, description: Moon Roof). I took the 20A out, put the Add A Circuit in with a 10A fuse (limitation of Littlefuse brand) in the appropriate slot. When I tested it, it was Constant
If I had a Moon Roof, I would have tried a different slot holding a fuse for something I didn't have and then test for Constant or Switched.
The CIG fuse should be switched.
I hope this helped.
1 - 2 of 2 Posts
