I'm not a Toyota enthusiast, but I feel enthused any time I work on my old Corolla. It's been faithful to me for two decades--I've never owned another car--and anytime I put hands inside it, I'm surprised by the ingenuity and resiliency of its design. Slowly I'm becoming a car guy, and a Toyota guy, too.
I own a 1997 Corolla with 207k miles and I've never changed the timing belt. It's time to do so, but you guys know more about this than I do, so I seek your advice: What components should also be replaced during this project? What important parts can be changed during this maintenance to extend the life of this quality car?
So far I plan to do the following:
Additional Maintenance:
I want to extend the life of this car as long as possible because it is good workmanship and reliable. I don't need fancy things in life, just things that work, and Toyota seem to work really well.
Are there any special tools needed for a timing belt change? From Peter Finn's Youtube guide (My Toyota Repair Bible), I see that you need a couple things:
-A floor jack to lift the engine (For clearance when removing the belt)
-Metric T-Bar handle & Sliding T-Bar
-10-18mm Sockets
-A specialty puller for removing a pulley (Can probably rent at AutoZone/NAPA/O'Reilly's?)
I want to make sure I have everything I need because I get anxious on new projects, and I will be working on my car on my landlord's extra driveway. He is kind and generous to let me do so, but I don't want to inconvenience him by asking for him to drive me to the parts store because I forgot something.
You are experts at this, moreso than I am. I seem to only learn out of necessity because time wears down parts and then I must replace them. I'd like to get a headstart on things and figure out repairs I can do now, early. Preventative medicine vs treating an illness. I've read about changing spark plug hoses, and I don't know how necessary that is, but there's surely other things out there that can be done cheaply and will greatly benefit my car's life expectancy.
Here's a picture of my Corolla, my workhorse.
- Change Timing Belt
- Change Tensioner
- Change Water Pump
- Replace Valve Gasket Cover (It leaks oil)
- Replace Thermostat (Throws out engine codes sometimes on really cold days)
- Replace Speed Sensor (It sometimes goes out... It is really deep in there so I've had trouble accessing it, but plan to figure it out.)
-10-18mm Sockets
