1 - 4 of 4 Posts
G
I am about take out my old header pipe and replace it with a new one.
This is on a 1991 pickup 22re extra cab 2wd truck with 230,000 miles. I
have all the parts and I know that I will be cutting out the bolts
since I don't see any bolts left to grab onto. Any other advice to help
make it go smoothly will be appreciated.
Also, since I will have to cut my bolts, any particular size or type I
should replace them with. Thanks and Happy Holidays.
G
Discussion Starter · #2 ·
Use a nut cracker (if there's room) or grinder to cut the nuts off without
damaginf the studs. New headers will brobably be a little less thick so
you'll have good threads left on the studs if you are careful. Avoid cheap
headers they don't fit and they leak.
<[email protected]> wrote in message
news:[email protected]
G
Discussion Starter · #3 ·
Go to www.lcengineerng.com you can buy a new header stud kit from them...
I'm not sure why it is that you need to cut them... but they are studs, not
bolts... it may be very difficult to get the studs out of the head if you
cut them all off. so just be Advised..
ian
G
Discussion Starter · #4 ·
Sorry if I sound skeptical, but are you sure you want to do this? And, if
you're sure you want to do this, why ask us?
The manifold bolts are probably not bolts at all, which is part of why you
can't find them. I think that cutting these very improtant bolts off is a
huge mistake for "normal" service of the exhaust manifold. Sure, you may
need to cut a nut or two, but that is not the preferred method of getting
the manifold off.
You told us that the current header is a '91 with 230k miles, but that alone
is not reason to replace this part.
1 - 4 of 4 Posts
