I'm pretty sure you need a MAP sensored 4AGE from japan and the wiring harness would help too. But i don't know off hand which years were MAPed to give you a direction to look.
gl
I'm pretty sure you need a MAP sensored 4AGE from japan and the wiring harness would help too. But i don't know off hand which years were MAPed to give you a direction to look.hi guys
i have a ae86 gts usdm with 4age but i want to convert to jdm with map i have the ecu jdm but what else I need to make this conversion very much appreciate your help
do you wanaa sell the tranny out of ithi guys
No, you need the jdm ignition stuff, and its rare and pricey,, good luckbut i dont know if i can use the same distributor and igniter in the jdm ecu
