SO after lots of research and way too much time spent on a computer I have decided to pretend a 4age engine does not exist because a swap is not as easy as everyone makes it out to be. I would never really use all that power anyway. So im going to focus on making the 4af engine a much better one then take money and put it into other parts of the car like the suspension and brakes and what not. I am trying to decide on the type of rebuild kits I will need and what kind of a carburetor i will need. I am looking for both performance and fuel economy if that is even possible. Anyway I want to put a scoop into the hood and force the air into the carburetor so it is inside of this pressurized chamber. So my question is what kind of weber kit should i get. Then maybe someone can also let me know if i need to change the ratio in the engine.
My rebuild kits of choice are #13 on the list
http://www.importperformanceparts.net/imports/pek-toyota.html
or
http://www.rpmmachine.com/shop/index.php?l=product_detail&p=5457
Also for this project im putting in a pacesetter exhaust, should I put armor coat on it or wrap it without armor coat.
Then im going to put in an aluminum flywheel
Does anyone know if replacing the cams to 244 or 252 degrees is woth it? it cost 519 to get a set
http://www.importperformanceparts.net/imports/webcam-toyota.html
This is a lot of questions I know but the more research i do before i jump in the better the rebuild and upgrade will go i hope. Anything you know and can post it will help. ..... ok im done :clap: thanks for your guys help
or
