Tested the TPS on the wifeys 4 cylinder 1990 Corolla.
The engine will start and idle, give it throttle and the noise changes but no revs, just idle.
I tried testing the TPS mounted to the TB but was not sure the alligator clips was holding on. Removed the TPS and got the clips onto the terminals. Could get continuity only at WOT position or there abouts.
Looking in Rock Auto and there are quite a few brands of TPS units. All aftermarket I am sure.
The brands are, Facet, Beck Arnley, WVE, Standard Motor Products, NTK and Walker.
Has anyone had any experience with any of thses brands of parts and what a good recommendation would be.
I know on My American built autos I have had good experiences with the Standard Motor Products on ignition components when I could not get the OE parts.
Any recommendations would be appreciated.
PS: this is the TPS that has three wires and is shaped sort of like a square box.
Thank You all in advance for any recommendations.
If the $150.00 OEM sensor is the best way to go, and it is still available brand new, the I guess that will be the way I will go.
