from the Camry sticky FAQ
S2000 Antenna Conversion
- Spectra Blue Cam
THE CELICA/S2000 CONVERSION WAS AN UNQUALIFIED SUCCESS!!
I had toggle switch to get my antenna up and down because unlike the factory decks, aftermarket ones don't care whether you're listening to the radio or not, it goes up all the time. With that switch I can put up the antenna only when necessary. But my recently-added RMM wing hits the antenna when the trunk lid is up. Also, it doesn't go up all the way anymore. So I've been investigating into doing the conversion.
I knew it was a good sign when only one day after I was told the S2000 antenna was backordered for weeks, it arrived.
The whole process took about 45 minutes. 25 of those minutes were spent twisting and bending the antenna bracket to bolt onto the support.
Here's the deal:
1. S2000 antenna - PN 39151-S2H-E01, $34.26
2. Celica sub-antenna (includes bracket) - PN 86309-20300, 35.60
3. Celica antenna nut - PN 86396-20030, $15
The prices are from Sisley Hondau (Yonge and Steeles) and DVNLT. Prices are in CDN, before taxes.
It's basically a bolt-on exercise. The only modification required was to trim a bit off the bottom part of the "antenna ornament" (official parts dept. name for the rubber boot on the rear quarter panel around the antenna). As mentioned, the most challenging part was twisting the bracket which came with the antenna to meet the existing bolt hole.
Reception is excellent.
