Comments on aftermarket DVD for SE? (dealers in Canada please)
Yes do post pics. I will pick a couple up if the picture quality works well. I have purchased many things from China via EBay and have had great success.Just received the headrest DVD today, It is quick they ship by UPS and less than a week I receive it. It is made by Xtrons and yes made in China and Iphone make in china too. You wont' say anything with this price for a pair of 9" DVD. I won't install it till this saturday and will post some picture.
so you connected the power to the rear on one of the 12Volt socket. So when you start your van, does the DVD player turn on or you have to power it on EVERYTIME from the unit?Yes at this price no complaint, I went to a local store and they quote me $900 with installation with the same stuff! The wire totally hidden! I first run wire under the seat and then remove the centre compartment box (10mm socket will do) then remove the cup holder by pulling upward. then I run wire under the box to the front of the 12V socket. But I actually connect the wire directly behind the socket. You simply pull the upper 12Volt socket out then you see two wire behind the socket. Then I use a (cloth hanger bend it) and run wire to the side and then to the rear. There are two fuse box from the DVD I just hide it under the bottom tray there are two little space just fit after you remove the box you will see it. hope it help I saw they sell at $259 include shipping now! $20 less
Not your problem just my bad explanation,
First the DVD wire will run from the headrest hole down the inside of the seat back. then guide the wire to the bottom of the seat then from the bottom of the seat you see air bag wire(yellow) the you just tie with those wire. Under the seat there are carpet you will find a cut from the carpet(it let the airbag wire go through) the you remove the center console(storage box) with two 10mm nut. Then from the bottom of the seat guide the wire under the carpet to the storage box area, from there you has to remove the 12v socket under the shift gate you will find two wire from the back of the socket test which is + and- the run extra wire to the center console area connect to the DVD done. Hope you understand if not let me know I will take some photo. I am not good in writing!
