why would you put a tach on a car that has one already?
because I am redoing the entire gauge cluster since my speedometer does not work with the transmission I installed.2wickedtoyz said:why would you put a tach on a car that has one already?
Nope. Cuz the Apexi one has a mini "computer in it so all I had to do was set the tach to "4 cylinder" and it was good to go.SBCelicaGT said:because I am redoing the entire gauge cluster since my speedometer does not work with the transmission I installed.
CamryPunk, I know where the wire is, I was just hoping somebody would know what the PPR is. Did your tach require calibration?
Awesome thread revival! For the record... I still have that tach sitting in a box and just this week I decided to finally get around to finishing up my cluster. I think you are right in that I'll probably have to go by trial and error to get it to read correctly.DoubleEdgedWomb said:Try it at idle and see what setting is right. You know what your idle should be at, because you've looked at your stock tach enough. Sorry I can't be more help.
