1 - 10 of 10 Posts
'06 Camry
i need to lower my low beams just a little bit. I've researched on the forum. All i found out was to find some kind of a screw near the headlight assembly... Can you guys clearify exactly where the bolt is to adjust the headlight ? thanks a lot
-jae
· Camry Gen5er
2002 Camry LE I4
'06 Camry
Discussion Starter · #5 ·
i opened my hood and checked thanks to your picture, zettahertz. But i found it to be a nut ? i can only turn it with a wrench. Does anyone know which wrench it'll fit ? i tried a 10mm wrench but it was way too big. I'm guessing its 8mm or lower. thanks
you can still use a regular screwdriver if it only has a nut. thats what the teeth and that channel is for... stick the screwdriver down that plastic channel and just turn the adjustment screw that way.
'06 Camry
Discussion Starter · #9 ·
oh wow, i feel stupid now. I went down to my garage as soon as i read ur post and it worked. lol almost spent $7 buying the wrench. thanks a lot LE05:clap:
1 - 10 of 10 Posts
