1 - 3 of 3 Posts
Vendor
error code B0136 seat belt related. Check all the wire connections under the seat first .There is different seat belt pretensioners and different ways to tell if seat belt pretensioner is good or bad. Some pretensioners have small metal balls inside, when the pretensioner is bad you will hear the balls inside rattling. For other seat belt pretensioners there is really no way to know by looking at it. Best way is to measure OHM resistance at the plug of the pyro sensor (electrical plug). Good seat belt would show resistance between 2-3 OHMs. If you are not seeing these numbers then seat belt pretensioner is bad. Hope it helps
Discussion Starter · #3 ·
helped bro. I will be checking all the steps
1 - 3 of 3 Posts
