Air Intake 4 A '90 GTS :?:
913 Views 6 Replies 4 Participants Last post by  port69
Has anyone had any luck getting an air intake for a 90 gts? I just got one from vibrant and.....it didnt fit!!! The tube is too long, it didnt come with an adaptor for the air flow meter, and there is an extra hole in the tube I dont need. Im getting pissed [Mad] . It seems like if I want to get something for this car its a pain in the ass!! Maybe I should have bought a Honda....NOT!!!!!!
I need some S.O.S!!!!
IDEAS?? [Question]
1 - 7 of 7 Posts
how much did u pay for you intake?
cut the tube and drill a hole for the sensor
the kit was $100, I have a MAF not a MAP sensor. It is square and bolts on to the oem air box.
????? what are you trying to make???
i got 90 GTS too.....and all i bought was AFM adapter plate.......
and one of the holes that on the pipe is for a vacuum line after the AFM....
I bought the "complete" intake kit. If you put a cone filter on the end of the MAF the battery is too far up and the coolant resivoir wont fit.
I know the one little tube that sticks out is for the vac. line, but there is a hole about an 1" in diameter cut beside it. I went back to part source and they say it is the same part # for the 1.8L corolla engine. WTF!!!! If I wanted something that I had to cut an modify I sure would want to spend less than $100!!!
If you have AFM you can't put an intake on your car.. well unless you custom make it. You can only put an AFM adaptor and then attach a filter to it. $50 bucks right there for filter and adaptor.
then the battery has to be pushed up and the coolant bottle wont fit. Thats why I am in this mess. I "modified" the stock tube but it still wont fit right.
1 - 7 of 7 Posts
