2008 Highlander Hybrid Limited with Auto AC
The air outlet control servo on my Highlander has died. I know it is a pain to replace but the issue I am having is I can't find the correct part # to order. Everywhere I look I only see the servo for the air mix damper but not the outlet control. I haven't disassembled it yet to see the part # as I wanted to have the new part before I did so. Is it a separate part # or can I just buy the air mix damper servo and use it?
Just so I make sure I am not an idiot the servo I am having trouble with is the one that changes the air flow from blowing in your face to your feet or defrost. It is on the passenger side sandwiched between the AC unit and the blower and a little higher up than the air mix servo.
Thanks for any help.
