1 - 7 of 7 Posts
'07 XLE 4 cyl.
Outside Air Temperature Sensor or what?
'07 XLE 4 cyl.
They are different part numbers on the Camry vs. ES350.
Whether they transmit on the same frequency, ????????
If they are the same, it requires a trip to the dealer to register the 7 digit transmitter number from each sensor into the tire pressure ECU.
· I Miss my I4VVTI
08 Camry SE
Discussion Starter · #7 ·
They MIGHT not work, the Lexus TPMS all have individual codes on each that have to be programmed into the ECU via a laptop to get that 'check tires' sensor to come off.
but rite now the Check tires light is off i reset the Light
so i must keep the Original one's rite ?
so for all the Camrys are same ? LE SE XLE ?
1 - 7 of 7 Posts
