1 - 4 of 4 Posts
92 camry
I installed an Autopage remote start alarm system in my 92 Camry. Everything works and I had no trouble installing it except I cannot figure out the wiring for the parking lights. When you lock or unlock the car the parking lights are supposed to light up but I can only get the lights on one side of the car to light up. What i've connected the wire from the alarm to is a green wire from a white connector below the fuse panel. Is there another wire for the opposite side of the car or somewhere different that i should connect the wire??
Thanks
Alex
Grenaded piston
Thats the correct wire and location. Theres no other wire for the opposite side of the car.
Your problem is weird. The parking light wire on the alarm is just an output that triggers the parking lights whenever the alarm is armed/disarmed.
92 camry
What do you suggest I do?? The parking lights function nomally on the headlight switch so i know that is not the problem. has anyone else run into a situation like this??
1 - 4 of 4 Posts
