1 - 3 of 3 Posts
Hi All,
I have a alarm system in my car.The fob says silencer and there is a Light below the steering wheel.I read some forums on disable the alarm.However there was no luck.
The problem is my battery was dead and i did tried to do a jump start also .
I did the following things
1) Tried to push the alarm light below the steering wheel but its not a switch.
2) I was looking for a fuse to disconnect from the ignition system but no luck
can someone please provide me some direction
Really appreciate u r help.Thanks in advance
Updates
Its not the alarm making the battery dead.The battery is already dead.
The picture for thr fob as below
http://cgi.ebay.com/ebaymotors/SILENCER-AFTERMARKET-KEYLESS-ENTRY-ALARM-REMOTE-w-PROG_W0QQcmdZViewItemQQcategoryZ33723QQihZ017QQitemZ270000719950QQtcZphoto
Thanks
07 XLE Camry
khetraps said:
Hi All,
Thanks
sooooo your trying to dis connect the alram???
you think the alarm is making your car die?
if so, i dont think the alarm would kill your car
there can be many problems causing your car to die..
exmaple a short in a switch that stays on killing your batt
but anyway its a factory alarm?
07 XLE Camry
also take apart your bottom half of the steering column and or center console maybe even behind the glove box..
im not to sure were the alarm is located
also this is a section in the audio video section for alarms
takes a whil for people to reply but theres a few guys that install alarms for a living on there
1 - 3 of 3 Posts
