So I had 3 alignments and it still pulls to the right. The alignment guy is really cool and said he would hit whatever spec I gave him, but also mentioned I may need to take it to a "4x4 specific shop who knows more about my components." - that'll cost me more and would be a hassle for me. Anyway, I used info from this site to guide him.
My setup:
DR coilovers set at 2.5 "s (even measured height on both sides)
TC Upper control Arms
285/75/R16 tires
Swaybar removed
The first time, I just had them do their own alignment. Then I told them it pulled right, and they first tried to flop the front tires and then had to align again because that didn't tell them anything. Then I gave them guidance from Toku's writeup. The spec is set at the following now and it still pulls right.
Front Left ---Front Right
0.0 ----------0.0 Camber
2.6 ----------2.5 Caster
0.00 ---------0.01 Toe
12.1 ---------12.1 SAI
12.1 ---------12.1 Included Angle
FRONT
0.0 Cross Camber
0.1 Cross Camber
-0.1 Cross SAI
0.01 Total Toe
Any recomendations for alignment help, or what else may be causing the pull? I can post the previous specs if anyone wants them.
My only thought I just had was this... I went off DR's install guide to put on the shocks and they said to make sure the shorter of the spacers on the lower mount should be facing the FRONT of the vehicle (for axle clearance
). This gave me swaybar clearance issues, so I removed the swaybar. Later I discovered All the other install tutorials say to have the shorter one in the rear. I don't see how that could affect alignment though.. just letting you all know everything I can about my setup. Oh yeah '05 Access cab 4x4 SR5
Thanks in advance.
My setup:
285/75/R16 tires
Swaybar removed
FRONT
0.0 Cross Camber
0.1 Cross Camber
-0.1 Cross SAI
0.01 Total Toe
Thanks in advance.
