Well, From what I remember, the values are not always 0.0. And there is always a range like -0.5 - 0.5 or 0.2 - 0.6 something like that.
I beleive that these values are a minimun and maximum value. Anywhere within these specs and you should have no problems at all. If I had to pick an exact value to be ideal, I guess it would be right in the middle of the 2 values (min and max).
When you get your alignment done, you will get a printout that has your original specs (values) and the adjusted values. On that paper it should also give you the min/max specs to fall within.
I'm not sure if this is helpful, and if someone has any different info, please post it as mines may be a little out-dated!
