Toyota OBD I Diagnostic Trouble Codes
by "THE CAMRY MAN"
OBD diagnostic does not have to be difficult or inconclusive.
On this OBD diagnostic pagefor Toyota vehicles we show you how to get the codes without special tools, explain the meaning of the codes on different systems and identify which system is not functioning
properly.
This information can help you fix the vehicle right the first time if you follow
proper testing procedures.
This is not meant to be a substitute for information and
specifications in the factory service manuals or the product service training manuals. If
you appreciate what is here for you, then just imagine how much more accurate and easier the repair will be with information from the product service training manuals.
Code Model Description / Probable Cause
12 Camry Corolla RPM Signal / Distributor or Circuit, ECM
13 Camry Corolla RPM Signal / Distributor or Circuit, ECM
14 Camry Corolla Ignition Signal / Ignitor or Circuit to ECM. ECM
16(1.8L) Corolla Electronic
Controlled A/T
Signal / ECM or Circuit
21(2.2L) Camry Corolla HO2S Sensor
Signal / O2 Sensor or Circuit, ECM
21(3.0L) Camry HO2S Sensor
Signal / Left O2 Sensor or Circuit, ECM
22 Camry Corolla Coolant Temp.
Sensor (CTS)Signal / Coolant Temp. Sensor or Circuit, ECM
24 Camry Corolla Intake Air
Temp. (IAT) Sensor
Signal / Intake Air Temp. Sensor or Circuit, ECM
25 Camry Corolla Lean Air/Fuel
Mixture / Loose Ground, Injector or Circuit, Fuel Pressure, Ignition
System, Coolant Temp. Sensor (CTS),Airflow Meter (MAF),
Vacuum Sensor (MAP), HO2s Sensor or Circuit, CompressionPressure, ECM
26 Camry Corolla Rich Air/Fuel
Vacuum Sensor (MAP), HO2s Sensor or Circuit, Cold Start Injector
or Circuit,CompressionPressure, ECM
27 Camry Corolla Sub-O2 Sensor
Signal / Sub-O2 Sensor or Circuit, ECM
28(3.0L) Camry Right HO2S
Sensor Signal / Right O2 Sensor or Circuit, ECMl
31(2.2L) Camry Corolla Vacuum Sensor (MAP)
Signal / Vacuum Sensor or Circuit, ECM
31(3.0L) Camry Airflow Meter (MAF) / Airflow Meter or Circuit, ECM
32(3.0L) Camry Airflow Airflow Meter (MAF) / Airflow Meter or Circuit, ECMMeter
41 Camry Corolla TPS Signal / Throttle Position Sensor or Circuit, ECM
42 Camry Corolla Vehicle Speed
Sensor (VSS) Signal / Vehicle Speed Sensor or Circuit, ECM
43(2.2L) Camry Corolla Starter Signal / Starter Signal Circuit, Main Relay,
Ignition Switch or Circuit,
ECM
43(3.0L) Camry Starter Signal / Starter Signal Circuit, Main Relay, Ignition Switch
or Circuit,
ECM
51 Camry Corolla Switch / A/C Switch, Park/Neutral Switch or Circuit, TPS or Circuit
52(2.2L) Camry Corolla(1.8L) Knock Sensor
Signal / Knock Sensor or Circuit, ECM
52(3.0L) Camry Left Knock
Sensor Signal / Knock Sensor or Circuit, ECM
53(3.0L) Camry Knock Control
Signal / ECM
55(3.0L) Camry Right Knock Sensor Signal / Knock Sensor or Circuit, ECM
71 Camry Corolla EGR System
Malfunction / EGR System, EGR Temp. Sensor or Circuit, EGR-VSV,
ECM
Hope This Helps :thumbsup:
:chug:
by "THE CAMRY MAN"
properly.
Controlled A/T
Temp. (IAT) Sensor
ECM
or Circuit,
ECM
Signal / ECM
ECM
:chug:
