1 - 3 of 3 Posts
Diehard Rams Fan
How many amps is the Toyota Corolla le 1.8L alternator ?
The standard output is 100 amps but I've seen high output ones that are 180-300 amp output available in the aftermarket.
Search for Mechman alternators.
They are expensive, so make sure your battery, your grounds (Big 3 +1 (Alt chassis to engine bay chassis)) are all grounded with 4, 2, or even 1/0 real OFC gauge wiring (not that crappy copper clad aluminum wiring).
And make sure you fuse the wire from alternator positive to your battery no further than 6" away from the battery positive!
1 - 3 of 3 Posts
