1 - 8 of 8 Posts
I wanted to report back a success. I've had my 92 4cyl Camry for about a year and a half. It had 420,000 km on it when I got it but had been meticulously maintained. I had my first no start issue with it on Friday - cranked fine, but no start. I checked fuses and found AM2 blown - replaced it and it blew again immediately. Did a google search and found the suggestion that it could be a blown condenser in the distributor - a radio suppression condenser #191133-16240. Suggestion was that the wire could be snipped for a temporary fix. Well, it worked. The wire is on the front of the car side of the coil and leads in towards the engine. There is a screw on the ouside of the distributor housing that holds the condenser in. While I was in there I noticed a little bit of oil, so I guess it's time to replace the O - ring.
Ron
92 Camry, 4 cyl, auto, 454,000 km
near Brantford, ON, Can
Toy Camry
Hi Ron,
Great work finding the solution so quickly, the resources of the internet are priceless !
I have a '92 Camry that just turned 460K. I'm excited about the prospect of watching it turn 500 (I've never had a vehicle with that many km's).
I've had lots of experience with these 5SFE Camry's and absolutely love them.
If I can be of any help don't hesitate to contact me,
Camray
im havin the same AM2 fuse problem with my 92 previa. where would this radio suppression condensor be located on my previa??
its the fuse that supplies power to the ignition system, and the fuel pump. its located by the main fusable links next to the battery....
1 - 8 of 8 Posts
