1 - 9 of 9 Posts
I'm a 2011 Crewmax owner here in Texas. Truck currently has 115k miles on it. I'm another owner with a diagnosed failing torque converter. The truck shudders @ 20-25mph and also between 35-40mph while being light on the throttle. Called the 1 888 number to see if Toyota would offer any acknowledgement and or assistance with repair costs. They denied any acknowledgment and offered no assistance. The dealership gave me a quote of $2579.45 for new converter, main seal and fluid change. Needless to say, I'm disappointed.
Discussion Starter · #4 ·
Update to my dilemma... visited two well established transmission shops that say " It's not just a torque converter swap. You'll be needing to rebuild / replace ant parts that are compromised. $1800-$2500 is the ballpark price range to fix correctly." So the Toyota dealership is merely a bandaid to fixing the actual problem. Gone are the days of high milage/ low cost Japanese type mentality, atleast in my wallet.
IMHO. $2,579. is to much. this is why we have independent shops. i have found that if a trans is less that 20-30 k miles if you put a good shift kit in it will last a very long time. the company i have used is Trans-go. and add a trany filter and cooler. i found a shift kit for my 08 Avalon. well be talking to my trans man this week.
Corolla, Camry, Tundra, Camry, Avalon, Highlander, Venza, Highlander
How often was the ATF changed?
Im having this same issue, been going on for a while and I thought it was something wrong with the trans, but after a while of research and noticing mine is just in the 20-35mph in auto but nothing in paddle shift.
I'm having this same issue but I'm wondering if its the TC or something in the drive train or even a joint going bad. I need to change the ATF cause I'm retarded and stick to the manual that says only check it and nothing about changing... I should probably change it first and see what happens.
1 - 9 of 9 Posts
