I replaced the Motor a year ago in my 99 Camry and all functions worked fine.
Got in it the other day and turned them on intermittent and they wiped 4 times before resting in park and start working normally in intermittent mode?
They return to park position fine, but I noticed the slowest speed is only about 2 and a half seconds at park before wiping again.
When I use slow or fast speed, they don't park. They just stop wherever when you turn the switch off, but if you stop in intermittent instead of all the way off. They will park and you can turn them off.
I have searched the posts and haven't seen a problem like this from anyone else.
You think the Column switch is bad?
The motor is not OEM, but the wipers work great other than this issue.
