1 - 12 of 12 Posts
Any camry would be good, but Gen 4 would be better. I understand that only toe-in can be adjusted and camber and castor are non-adjustable, unless camber kits are installed then camber can be adjusted. I have a DIY toe-in alignment tool and the front toe-in is 0.0mm while the rear toe-in is +0.5mm.
Thanks.
TN Pussy Man
Camry
this is what I have saved as the specs (for the gen3 camry at least)
F Left Camber: -0.56°
F Right Camber: -0.56°
Front Caster: 1.19°
Side-to-side Caster variation: 0.75°
TN Pussy Man
Camry
no real idea? :dunno:
since you're doing it yourself tho, why not just give it a try and see how it drives and looks?
The Other White Meat
Holden Apollo
Ken4 said:
-ve camber! Wow, that is really strange.
negative camber is normal. excessive negative camber is strange.
Mitsubishi Diamante Owner
'03 Diamante
2000-2001 Toyota Camry 4cyl alignment range:
LEFT FRONT
CAMBER -1.4 .02
CASTER 1.4 2.9
TOE -.1 .1
SAI 12.3 13.8
INCLUDED ANGLE 11 14
TURNING ANGLE DIFF. N/A
RIGHT FRONT
CAMBER SAME AS LEFT FRONT
CASTER SAME AS LEFT FRONT
TOE SAME AS LEFT FRONT
SAI SAME AS LEFT FRONT
INCLUDED ANGLE SAME AS LEFT FRONT
FRONT
CROSS CAMBER -.8 .8
CROSS CASTER -.8 .8
TOTAL TOE -.20 .20
LEFT REAR
CAMBER -1.5 .1
TOE .10 .30
RIGHT REAR
CAMBER SAME AS LEFT REAR
TOE SAME AS LEFT REAR
REAR
TOTAL TOE .20 .60
THRUST ANGLE ----- ------
These specs are from NTB and SEARS
94 v6 specs
Left and Right Front:
Specified Range
CAMBER -1.3 0.2
CASTER 0.4 1.9
TOE -0.1 0.1
SAI 12.3 13.8
Front:
Specified Range
CROSS CAMBER -.8 .8
CROSS CASTER -.8 .8
TOTAL TOE -.20 .20
Right Left Rear:
Specified Range
Camber -0.9 0.3
Toe 0.1 0.3
Rear:
Specified Range
Total Toe 0.2 0.6
Ken4 said:
Any camry would be good, but Gen 4 would be better. I understand that only toe-in can be adjusted and camber and castor are non-adjustable, unless camber kits are installed then camber can be adjusted. I have a DIY toe-in alignment tool and the front toe-in is 0.0mm while the rear toe-in is +0.05mm.
Thanks.
I'd like the same info, i have TRD springs and 18" wheels, was told to install a camber kit by a toyota mechanic, but I don't see the specs in my Haynes manual. I did pick up an OBX bolt kit on ebay for this....
Camry
i got tein stech, tokico shock and 18" rims....but america tire mechanic tell me i dont need install camber kit...stock will be fine
Discussion Starter · #10 ·
TOE -.1 .1
Is this in millimeters? inches? or degrees?
Thanks.
1 - 12 of 12 Posts
