Here's the story of my vibration/unbalanced tire feeling. It was initially at various speeds (just shy of being severe), then just highway (+70 light/just shy of moderate) and now back to various speeds (light/moderate depending speed and increasing intensity as time goes on) with a whooping feeling/sound @19-25 mph (this to me this is severe).
10/07/10 (milage 16) - purchased
10/08/10 (milage 49) - Test drove on a not so perfect road and misconstrued the vibration for the road conditions. The unbalanced feeling was all over the spectrum so I brought it back. Per the dealer there were flat spots on the tires due to the car sitting to long. Solution was to overinflate and drive. Also, disc were out of round causing vibration when braking
10/11/10 (milage 89) - vibration still present but the dealer said they couldn't feel what I was experiencing. The rotors were cut.
11/15/10- (milage 975)- acknowledgment of the vibrations so Dealer put new set of tires on it. But the vibration still present at highway speeds
2/19/11 (milage 5160 ) - vibrations still present, car pulling left when braking and accelerating- Dealer said they couldn't feel anything and I quote "It drives like a Camry"
2/21/11- car hit in the rear driver side tire - entire wheel assembly replaced, new rim, only body work needed was a rear bumper: vibration at HW speed still present
7/12/11 (milage 10127) - vibration at HW speed still present, dealer still not able to validate my concern
11/04/11 (milage 15355) - vibration at HW speed still present, dealer still not able to validate my concern
3/22/12 (milage 19973) -vibration at HW speed still present, now severe pulsation when braking- rotors resurface, road rest noted no vibrations, brakes smooth
06/08/12 (milage 24949) -vibration can now be felt at lower speeds 50+ with increasing intensity with speed and from 19-25 am intermittent whoop whoop feeling/sound. This happens every time I'm going this speed but not constantly. might do it at 19 maybe 23 then subside but come back. Per the dealer they were unable to validate only noting that they found very slight pulsation at highway speeds. The dealer agrees to have the car access by a Toyota factory rep.
6/10/12- The dealer called to advise me that they went over the history of the care with the rep and there was nothing they could do further as now the tires are to warn for proper evaluation. (left front is outside warn, almost bald, inside some tread; other 3 tires inspection passable) I will need to purchase tires in order for Toyota to address my concern
6/12/12- (milage 25087) filed a complaint with Toyota
6/13/12- Toyota rep called to tell me that they did snot warranty tires and I have to understand the Factory reps position that he can not properly assess a problem with defective equipment on the car. But was going to call the dealer to see if they can put new temp tires on for the factory rep to assess the car. And if they won't ? Told to wait and see as there isn't much Toyota can do if the issue is tires, I will need to either buy tires or contact Bridgestone.. (who will no doubly say there is something wrong with the car and isn't their responsibility)
Now waiting to see what the dealer/Toyota come up with.... any thoughts ?
Thanks
Kay
:headbang:
Thanks
Kay
:headbang:
