Are you loooking for any specific info?
Should be pretty straight forward:
Pull tranny
Remove pressure plate
Use pilot bearing tool to remove pilot bearing.
Remove fly wheel to have resurfaced.
Then reinstall everything, and make sure you have a clutch alignment tool.
Not sure if anybody is making after market clutches yet (centerforce) or if you are planning on going with stock. Also, how many miles do you have on your truck? Clutch failure shouldn't be happening soo soon, unless you do a lot of towing
EDIT - I guess I should have checked out your 100k thread as well
Pull tranny
