Roll down window
Pop off the power controls
Pull off the thing where the tweeter is located
Open the little square thing where near the inside lever and remove screw. Insert a screw driver between the plastic piece and the fabric and twist. It should pop the plastic piece out
Look in door handle and remove screws
There is a covered screw near the front of the door. Remove cover and screw
Look on the back part of the door near the latch and bottom of teh door and remove any clips or screws.
When all clips and screws are removed, grab the interior panel near the bottom or the door handle and pull. A bunch of clips should release. Lift panel upwards to remove.
