Here's a thread with some info for you...
http://www.toyotanation.com/forum/t138573.html
I have the Highland divider, the one you see on the red truck in those pics.
I had to drill a new hole for one of the feet since they don't line up perfectly with ridges in the bottom of the truck, but that shouldn't be an issue if you have a bed mat.
The other problem with it is that the bottom gets kicked out by heavy items, even with those feet. Next modification to it I am going to lenghten those feet considerably, probably by shoving some dowel through them, so it won't kick out.
The cargo net that comes with it is pretty tight so I find it useless. I might get a toyota cargo net and do what Elwinna did so I have something for grocery bags. Finally, one of the rubber pads that hold it agsint the bed came off, so I have to re-glue it.
It has served some function but I am not totally happy with it...I think a bed mat would work better to keep stuff from sliding around. Maybe the two of them in conjunction would be the ticket. That bed is so slippery that practically everything you put into it turns into a bowling ball and wreaks havoc.
