Can you use one of these to tune an engine that was once N/A and is now turbo. (With the use of larger injectors, and stock ECU, at around 8 psi)
Thanks everyone! Ben Harper
The neo will hold tune since the factory ecu will go into open loop when it sees the boostsure ca. But something to control the timing is also always a good thing. But at 8psi, a NEO tune should hold out for ya
